- Apr 23, 2018
- 6,886
@jdedmon91 , you should consider a billet bushing. There are a bunch of ways to stiffen the linkage, and when done right it'll feel like it's supposed to. IPG parts has been good to me, so I'm plugging them.
Hi Chuck can i ask is there any adjuster to go with that eccentric tail stock lock?.Reason i ask is i have a boxford lathe but have never noticed any adjuster for tail stock lock .And i know mines getting a little loose so wondering if it can be adjusted or if i need a new eccentric.Nice work that ChuckI spent some time this weekend working on a tail stock for my 9A. I did some trading for a Boxford tail stock that needed some repair. The camshaft and handle was missing and the end of the screw was pretty chewed up. I made the repairs and mounted it on the bed. Dialing it in will have to wait until I'm done with the bench so I can level it out. I took a cut the way it sits and it was off by 0.003 front to back. I can't seem to upload photos today. It says the file is too big for the server. Never had that happen before. View attachment 300515
Have been looking for a 3hp single phase 220-240V motor for the 216 Quincy compressor I recently got up and running.
You adjust the tension by tightening the nut on the bottom. Unless I'm misunderstanding your question. If you're talking about slop in the shaft, there is no adjustment for that. There's a set screw that fits the groove at the end of the shaft, but it just keeps the shaft from moving laterally.Hi Chuck can i ask is there any adjuster to go with that eccentric tail stock lock?.Reason i ask is i have a boxford lathe but have never noticed any adjuster for tail stock lock .And i know mines getting a little loose so wondering if it can be adjusted or if i need a new eccentric.Nice work that Chuck
Got it thanks ChuckYou adjust the tension by tightening the nut on the bottom. Unless I'm misunderstanding your question. If you're talking about slop in the shaft, there is no adjustment for that. There's a set screw that fits the groove at the end of the shaft, but it just keeps the shaft from moving laterally.
What kind of 3 phase power do you have in your shop?
I have RPC generated 3 phase, but this is a 230V single phase motor. Mike
