Quick POTD for my wife. She has a solar-charged LED motion-sensor flood light on the pole barn at her garden entrance. Well, the aiming post for the light broke from the wind(?). Figured aluminum would make a good replacement.
Really like these LED motion-sensor floods. Have them in the storage section of our barn for no-hands lighting
Support/aiming post broke
Chunk 'o 1" aluminum for a replacement
Challenge would be duplicating the ribs which engage a splined mating piece to keep the lamp from rotating.
Post has an M4x0.7 nut set inside a hex-hole for attaching to the light bracket
Only challenge was the plastic shaft had three ribs that engage with a mating bracket with grooves to prevent the shaft from turning. I figured the easiest way to replicate that was to do a straight knurl on a couple of areas of the aluminum shaft. The plastic ribs stick up about 0.008", but how much for straight knurling on aluminum? Turned the aluminum blank to a known oversized diameter, mic'd and knurled with a Rockwin hand-knurler. Ended up increasing the diameter by 0.005".
Turned the shaft to final diameter and hand knurled a couple of bands.
Turn to a diameter for development of how much diameter increase would come from knurling
Hand knurled and mic'd the shaft at ~0.005" larger. Not quite the 0.008" of the plastic but "good enough"
Turn to final diameter and chamfer the end
Knurled the shaft in 2 areas
Next step was to mount the piece in a 5-C collet and square collet block and go to the mill. Found the edge of the shaft's shoulder with a laser center finder. Center in Y was easy as my mill vise fixed jaw is always at 0.000". I paint marker the width of my square collet block for easy setting to the center of the work (0.864" in this case). Milled away half of the surface (hole at the end was a leftover from a previous job).
Spot and tap drilled for an M4x0.7 thread. Tapped manually on the mill with a tap wrench with a slip-fit shaft for alignment.
Found the shoulder of the shaft with a laser center/edge finder
Milled away half of the top of the shaft
Spot and tap drill the mounting screw hole
Tapped the M4x0.7
Finished part and original broken shaft
Screwed the replacement shaft to the light and remounted to the wall bracket. Works and my wife is a happy woman again!
Thanks for looking,
Bruce
replacement shaft in place
rabbits beware . . .
