Didn't make it in one day, probably around 30 hours time. Put in a set of shelves in my shop 8' x 6' tall x 2' deep about 15 years ago. They were organized at the time . . . Boxes of screws, nails, bolts, cans of stain, air nailers, etc., etc, etc. have been shoved on the shelves over the years. I invested in a few Rubbermaid tubs to throw in like hardware like electrical, cabinet and plumbing stuff. So need an electrical switch, pull out the tub and dig through it to get what's needed.
Plan is to replace the storage rack with a pair of 4' tall x 4' wide x 2' deep drawer units. Made the cabinet out of 3/4" plywood, drawers out of 1/2" ply. Had our 22-year old son in the shop to help with the cabinet making. Gave me a chance to pass along some tips/tricks I've learned over the years like how to cut a dado in the dead center of the top/bottom so it's perfectly centered so drawers are interchangeable side to side. I use a 1/2" dado blade and cut the dado close to center, then flip the board and make a second pass running the opposite side against the fence. Then measure the width of the dado relative to the width of the divider board and move the fence away from the blade a little less than half the difference. Keep making passes with opposite sides of the top/bottom against the fence with little taps on the fence until the divider just slides in (sand a little taper on the sides of the divider at the top and bottom).
Anyway, made good use of the dovetail router fixture fixed above. Drawers are 3", 4", 3 6", 8" and 10". They're mounted on full-extension glides rated at 100 lbs., so doubled them up on the 8" and 10" drawers just in case. The glides are pretty cheap nowadays. Got 30 sets of 22" full extension glides off eBay for $135 including shipping. I remember these being something like $15 each back in the day. Brushed on 3 coat of polyurethane for a finish, no stain. I set the drawers back in the cabinet enough to put doors on, but will probably leave them as is. The spacing is 3/16" between drawers which is hopefully a little too small for mice to squeeze into!
Next step is emptying the rack and getting it out of the way for the first of the two cabinets. I'll start filling drawers and will make the second one based on what's left to store. Would hate to make a couple of banks of 6" drawers and find out I need 7" deep ones.
Thanks for looking!
Bruce
