Today i wanted to finish with the installation on my car's stereo, it come with an reversing camera so i decided to install it, run the wire under the carpet to the trunk. Then i had to choose where to mount it, i chose to cut out a piece of the licence plate holder and glue it with windscreen adhesive, there was a hole in the bumper to run the cables thru , also found a empty gramet to bring the plugs in the trunk, from there should be easy as connecting to reverse light but my reversing lights decided to stop working. so i spent half an hour checking fuses wires connectors, on this car i've done an engine conversion from v6 petrol to an turbo diesel also used to be automatic now is an manuel so i've been thru the wiring to make it all work and found out the switch on transmission is defective. I'm a person who has two spare parts of everything, the first gearbox i went to, this switch was broken the second one was from a much older model and has different connector, so i cut off the connector and crimp new ones after insulating all the connections with row rubber to make them weathertight i put everything together and works nicly.
