Replaced the battery in my iPhone 5S. Only 2 moments of panic, and 1 moment of stupidity.
Panic:
1. Prying the screen off initially with the suction cup, didn't control my strength well enough, and pulled the screen up too far, pulling out the connector for the home button/fingerprint sensor. However, once reassembled and powered up, it works fine.
2. After reassembling it, it wouldn't power up on it's own, and just displayed the low battery icon on the screen for about 15 minutes or so. Finally plugged it onto a wall-wart (they have the highest power output) for about 15 minutes, then it did power up. Evidently, the battery was completely out of power...
Stupidity:
There's a small cover over the connectors to the display, with 4 screws. The video I was following along with did the "Remove these 4 screws. Make sure you put the screws back in their corresponding holes". Naturally, I stopped the video after the first sentence, removed all the screws and put them together, unordered, hit play and then heard the second sentence...doh. I had broken my "rule" of watching the whole video for doing something, prior to doing it, so I know what to expect to do and to catch dumb things in videos like this. Anyway, found a site that described the 4 screws (2 1.7mm long screws, a 1.4mm screw and a 1.3mm screw) and which hole they belong in, then got out a magnifying glass to figure out which goes where.
Anyway, it's all back together and working. The old battery lasted about 4 1/2 years...
Panic:
Stupidity:
