Today i spent half a day in the back of the Lada, cutting out all the rust, first to go was the rest of the trunk floor, i ground out the spot welds and removed the rusty metal, also takald the right wheel arch rust, i cut off all the rust it had and then used a wire brush on all the edges and other loose rusty metals. I also stripped the back end, removed all the lights, wiring, trailer hitch, bumper. then i started making the new boot floor, i started with 1,5 mm cold roll steel, cut it to size, bend a edge like the original, then put it in place and marked it and punch it for spot welding, then i realized that i'll be better off if i repair and reinforce the rear bumper mounts and add stronger structure in the back so i can attach a new trailer hitch behind the bumper, so i stopped and i'll be visiting the steel shop for some square tubing for the structure.
