Arrived and unpacked today. Greenfield Tap & Die No.7 and No.5 (to go with my No.6), Starrett 91B tap handles and an unbranded forged steel die handle.
Dismantled, quick going over on the wire wheel to remove the surface rust, greased and reassembled.
The GT&D No.5 fixed jaw is not original and a pretty poorly made mild steel replacement. I have some suitably sized HSS so will probable make a replacement next time I’m surface grinding something.
Also a surgace gauge. But the fine adjust screw went missing somewhere between the original seller, my forwarding service in the USA, and actually arriving (with a small hole in the box). Should be able to knock up a replacement if I can figure out the thread.
