- Jan 28, 2011
- 3,613
We have a slitter at work that has no thrust bearings so the two shaft MAY move side to side. So I suggested making a couple of blocks that would preload via a plunger that is spring loaded using some spring washers and an adjusting screw. The plungers sit in the centers that are already on the shaft ends. All lathe work except for the band saw to cut the 2" aluminum blocks. The thread is 11/16 X 18, yes 18! So turning, threading, reaming, knurling, drilling, boring, etc. Basically just about the whole gamut. I supplied the tap and knurling tool.
