- Oct 30, 2012
- 956
Ya I bought one standard shelf bracket and then reverse engineered the hook profile. Designed the side profiles to match the standard lumber widths. Brackets are 16 ga 430 SS cut on laser. I went thru several iterations before finding the down angle that worked best.
As far as wood causing rust I have heard that potential issue but in all the years Ive used it for my Bp collets, drills etc never once had a spec of rust on my tools. Could be I keep them cleaned and oiled?? Also my basement shop is relatively dry and constant humidity so maybe that is part of it. I do have some 3/4" hdpe I can use but the pine is cheap and easy to cut to length, machine and test various hole patterns. I could easily have just fabricated the whole shelf/side bracket as one integral pc of ss but Was trying to keep things simple (minimal press brake work) and not be locked in to a fixed width.
Heres the profile.
Heres the profile.
