- Sep 5, 2013
- 3,996
For now, I think I will use the same method I use for my truck block heater. I used to forget I had it plugged in and when approaching the truck from behind I could not see that it was plugged in. I drove away with it plugged in a few times and finally came up with a solution that works well. I drape a bright green extension cord over the drivers mirror whenever I plug the block heater in. Reminds me its plugged in. No problem since doing that. I can use the same method with the lathe. If I'm going to use the indexer I will unplug the lathe and drape the power cord over the headstock by the chuck. For now the whole assemble has been removed and is stored away for some future time. I didn't want to leave it installed
I have a few of these "flags" in the shop that I use for times when I've done something out of the ordinary to a machine setup. I borrowed the idea from the streamers they use on planes when they're parked. The red woven stuff is like webbing except it's two layers like a sleeve, so I could slide a small magnet inside the tube then heat-seal the end to keep the magnet captured. The yellow tag end was a separate bit of webbing just for added contrast and visibility. Maybe overkill, but I got carried away in the design aspect a bit.
Yes I still have to remember to use them and they're not fail safe, but I find them useful. And with the magnet there's always a place to just slap them on with no fuss.
The green extension cord idea reminded me of these, so I thought I'd show.
-frank
