- Nov 23, 2014
- 2,646
One of my more satisfying POTDs; made my wife smile. We have been blessed with a very nice home. Our entryway is open to 2 stories and as the weather starts to cool we get unwanted house guests in the form of lady bugs. Hundreds of them get in someplace and ball up at the peak of our foyer. I’ve set up an extension ladder and carried a vacuum cleaner up with me to get them in the past. Gotta be a better way, of course, a POTD!
Took an attachment and measured the ID at two depths with a telescoping gauge to get the taper and ID of the opening. Also measured the OD of a 10’ length of ¾” PVC pipe. Little bit of sag in the PVC when held out flat, but it was a lot lighter than thin-walled conduit and only dropped about 6” at 10’.
Chucked up some 1 ½” Delrin and drilled/bored a 0.90” hole (ID of the ¾” PVC). Then bored the PVC end 1” deep to the OD of the PVC (1.060”). Flipped the adapter and set the taper attachment to 0.5 deg. Really nice to have a DRO on the lathe for tapering. The X (diameter) would move with the Z (longitudinal) IF I had turned the cross feed clockwise to take out backlash after turning CCW for a deeper cut. Checked the fit with the wand end of the vacuum when I got close.
Used some Gorilla glue to attach the ¾” PVC to the adapter. Project sucked, just like it was supposed to. No more lugging a vacuum cleaner up the ladder for me!
Bruce
Bruce
