Made a flat plate to hold parts horizontal, good use for a bunch of these 3/4" Alum plates I have . I made the part , then I realized I could modify it to hold some saw blades I wanted to enlarge the arbor.
This Ryobi blade was the guinea pig . I indicated it to dead center then used first a 1/2" carbide APKT1003 end mill , then 5/8 , then 3/4, then 1" APKT1003 and then the boring head til the arbor just slipped in tight .
Saw blades are TOUGH STUFF ! The Alum plate had a big bevel on one side , did a build up weld on that , then welded in some gussets into the C channel steel base .
Squared up and faced the C channel on 4 sides, faced the Alum plate , drilled, countersunk and bolted together. Tapping the alum was a pita ...very gummy stuff . All part of the learning process
with each thing I build I realize i've got alot to learn. I figure I might as well build something while im learning...no shortage of mistakes and realizations !
