2016 POTD Thread Archive
On another note, this beauty will arrive in about 3wks or so, 10 tools, 40 taper, 8000rpm and comes with about 70 BT40 holders of various types. Machine has the rigid tap option. It's a 1996 yr model, and yes I will be able to feed it CAM programs :)
Well you didn't mention getting it all for $500 so I'll refrain from telling you that you suck. :)
2500 for the Machine, 3500 for shipping....
I'm excited for it to get here, I have to admit tho that i will be down on milling until i can get power for it. My cnc knee mill is currently for sale too, to make room and also reimburse my expense
Something that may deserve a you suck is that the seller is going to send me the Machine without paying, when I get it and everything checks out then I pay, if it's effed up, like bad control, the Machine is of no cost... it needs a bearing for the Z axis screw. The seller is really a good guy.
I love the challenge of maybe having to fix something, after all I don't rely on my machines for anything other than pleasure at the moment.
Well a bit of a project in the making, but finished it off this last weekend. Here is a shot of the backing plate I made for my lathe. First test was about 0.001 out so took a smaller fine tool and made a couple of light passes and this was the result.
In my opinion .0000" is close enough. Good job!
Tom S.
Update, Went back out and played with the new backing plate, took it off and marked for holes, then remounted it and playing around with my new gage holder and found that the mounting was not repeatable. Every time I took the plate off and put it back on the readings were different. Only a few thousands but to much for fine work. Think there is a bit to much play in the threads, allowing it to cock as it spins on. First try and learning curve as I have never made a backing plate before. Though about boring it out and plugging it and try again, but not sure that would work. Oh well Have another piece already just have to start on it, wish me luck.
A customer ordered 100 PVC bushings, so I needed a quick & dirty way to make them. 2 inches long, OD ~2.38, ID 2.00. Schedule 80 PVC pipe is 2.375 nominal OD, by about 1.95 ID, so very close to the finished ID dimension.
So first cut a little a little long in the chop saw, well not quite that long :grin:, but you get the idea.
My 25 year old Black & Decker/DeWalt is still going strong.
Then over to the mill to the ultra expensive MDF dual fixture. 3 layers of 3/4 inch MDF, screwed & glued together. About $2 in materials, and about 30 minutes to draw it up and build it. Pocketed to fit the OD, the halves attached to the soft jaws so it opens up when the vice is released. I made the fixture in one piece, then took it out of the vice and split it on the table saw. The flat head cap screws relocated the fixture in the vice.
I did it this way because if I put them in the 3-jaw chuck in the lathe the pieces would deform unless I made a set of soft jaws for the lathe that form fit the parts. Then I would have had to do all of the work manually, doing it in the mill, I can load the parts, press go, and walk away for a few minutes and work on another project. I machined the vice soft jaws at 1.5 inches high so the 3rd layer of MDF would sit flush on top of the other two. I rarely use hard jaws on my vice, and just make soft jaws as I need them out of steel or aluminum.
And this is the way they fit. Face off one side, then flip over and run the finish height cut and bore all with the same tool, a 1/2 inch dia, 2 inch DOC, carbide tipped, router bit.
Repeat 50 times :faint:, then change tools and corner round the ID. Total time per each is about 6 minutes. A little long at $5 each+materials, but that's what the market would bear. Sometimes you can't get what you want, but it still helps support my tool habit. :grin:
Maybe it's too loose on the spindle register, or otherwise does not have a good fit in that area.
Because I just got my first lathe, I am a real beginner. I wanted to learn how to grind my own cutting bits but my grinder is an old 6 inch that my son keeps pretty busy with his blacksmithing projects. He keeps 36 and 60 grit wheels on it and I didn't feel like changing wheels every time I wanted to grind a tool. So I went to HF and with my 25% coupon, I bought the 8 inch grinder. I didn't even open the box until the wheels I ordered came in. I figured the stock wheels would be out of balance and didn't want to fight them.
So, when the Norton wheels came in I put them on and started the grinder. It just about jumped off the workbench. So much for an easy fix. I tried to balance the whole thing as I have before, but just could not get the wheels to run true.
I pulled the retaining washers and trued them up on the lathe. That helped a little, but not much. I had seen a guy on YT who balanced a HF tool grinder and decided to try some of his ideas. First I machined a spacer to go between the inner washer and the bearing. It just clears the frame of the grinder and it provides a much wider surface for the washer to register on.
Next I noticed that the plastic spacers they provide left about 1/32 inch play in the wheel so I made a new spacer to fit better.
Once i got it all put back together, it purred like a kitten. It still has a little vibration but I do believe that will clear up when I get the wheels dressed properly. I am building the tool rests for it similar to the Wolverine style rests
