When my wife and I were on vacation in NW Montana a few weeks back I had my main battery short out in our Jeep. I installed an Optima Yellow Top from a NAPA store while I was there and decided I would replace my auxiliary battery now to match so they would be matched.
I am sure this installation was overkill but hey, overkill is under-rated. I wanted to be able to keep the handles on the batteries because they are hard to install/remove as is and without a handle it would be nearly impossible as they are shoe-horned in there as is with my dual battery tray and setup. The Optima battery handles easily slip off out of the groove, however, then I would have to store them somewhere and more importantly remember where they were when I needed them. I figured it was just easier to leave the handles on the batteries and fabricate a spacer to span across the handle.
I cut two pieces of 2" wide by 1" thick 6061 aluminum that I had on the rack each @ 4" in length. I then clamped each one in the mill vise and began machining. I started by finding center in both X and Y directions.
Next up was to cut a slot for the handle to reside which was 1" in width and .5" deep.
After the groove/slot in the bottom was completed I flipped the parts over to machine the top side. I was almost going to just leave them and place the hold-down across the top but then my son gave me a great idea of milling a slot that was just wide enough and deep enough for the hold down to fit in and the cut would act as a locator. Great idea son. Here I started cutting the .125" deep groove lengthwise in the block.
Here is the top slot nearly completed. The two small tabs remaining on the sides will act as locating ribs and the hold down bracket will sit flush with them as they straddle the battery handles.
Blocks completed.
Test fitting them on the batteries.
Installation completed.
Hey I know, way overkill but I wanted to use my mill last night and this was my opportunity. Besides I guarantee it is unique.
Mike.
