2016 POTD Thread Archive
Super write-up & pics Jim. Soup to nuts.
I've never run across, or thought about, stainless steel tape (I've used stainless foil) but now it's on my next McMaster order. That's two things I learned today.
Thanks.
Thank you for the kind words.:tranquility:
I think I bought that roll of stainless steel tape at Home Depot or some such place about 25 years ago. Don't use it too much, but is's nice to have around when you need it.
My neighbor broke one of the rod ends on the steering cylinder on his Massey-Ferguson tractor. The only replacement part available is the complete cylinder assembly for big $$$$. :eek: He found another rod end that had the same taper dimensions and would kinda work so I get the task making it work. I need to get the tractor back on line anyway because I need to use it to finish getting through my jungle of a back yard.;)
This picture was taken after I cut the broken part of of the cylinder and had the cylinder set up in the mill. I just used the band saw to cut through the weld and then just ground off what was left. The reason it is in the mill is that the rod end has a female thread, rather than the normal male thread, so I have to increase the size and move the locating pocket in the cylinder tab.
I didn't have much height clearance so the cylinder needed to sit on the table. The good news i that I have a precision machinists vice to grab the cylinder. I could have used an angle plate and lashed up something also. I could have even run a bolt down through the cylinder and secured it right to the T-slots.
And another view of the setup. The mill vice holds one side just fine, but I couldn't just leave it hanging out in space, so clamped and supported on the other end. The clamp is pretty much centered over the jack screw.
I chucked up the new rod end and just took enough off to get a round surface. Size didn't matter, just round (ish) It came out at 0.7165. A lot of tool hang out to clear the taper.:cautious:
And kinda in place, but a tad long. I'll fix that later.
So now to bore and move the hole over. I am going to go through so it needs to be moved about 0.090 away from the cylinder tube and bored to 0.716 to get a light press fit.
I thought I was going to rough out the hole with a 0.625 end mill, but the the tab had other ideas. The weld area was a bit on the hard side and it just laughed at my HSS end mill. :D OK, time for the big guns, CARBIDE. I just ran a pocket routine and machined the bore, came out perfect on the first try. Didn't have to make a spring cut.
OK, time to trim the rod end using my junk import vertical band saw, complete with HF blade. A couple of aluminum scraps to support the part while cutting.
So once cut off I welded it in place. 3/32 7018 rod, 95 amps DC reverse. I put stainless steel tape over the rod hole and over the taper on the rod end.
And the back side. That weld is not as ugly as it looks, the center of the rod end is hollow. My HF needle scaler in the back ground, actually has worked pretty good for a number of years.
I had to be really careful not to let things get too hot. I was worried about the seal in the cylinder. No way to get it out without destroying it. So weld a bit then blow air, let it cool down, rinse repeat. The seal never got over about 140° F
Then on reassembly I found the cylinder rod was bent, had about 0.250 TIR bend in it:mad:. So over to the press and get it more or less straight.
And the finished assembly ready to install. This is going to cost the neighbor a couple of his grilled hamburgers, each one is about two meals for me. :) I work for food! :rolleyes:
Hi Jim,
Great job on being so "neighborly"! I think he owes you a little more than a couple of hamburgers. Excellent fix.
Bruce
Sold some old toys on eBay which funded my jump into TIG welding. Bought an AHP 200X welder shown below. I still need to do a lot of practicing, pictured are my first attempts at laying a bead on (top to bottom) Aluminum, 0.023" sheet metal and 3/16" CRS. OK, I didn't attach the picture of an Aluminum bead with the welder in DC mode . . .
POTD was making a filler rod storage rack; still need to label them Steel, Stainless & Aluminum. The caps/rings next to the PVC tubes are for shorts of the same material. Pretty simple rack, schedule 40 PVC and sheet metal. Of course, after the fact I'm reconsidering the use of plastic around hot metal, but that's what the fire extinguisher is for!
Bruce
View attachment 133110 View attachment 133111
Jim, great job on the repair. Does the cyl run on the tractor hydraulics or does it use a separate pump? I have an older Kabota tractor the doesn't have power steering and it is a bear to mow the field. The workout was great 20 years ago when I first bought the tractor but not as much fun now. I'd love to add a ram assist to the current steering setup, especially if I can use the on board hydraulics for power.
Thank you for the kind words!
I think that one uses the tractor hydraulics. There is no direct mechanical connection between the steering wheel and the front end. The steering wheel is connected to a hydraulic steering valve just like many forklifts and other hydraulic off road equipment. A pretty common item in forklifts for the last 40 years or so. If you wanted to go buy one I would be looking at that used forklift parts place, on Columbia Blvd, just east of I-5. Another place that might have one is that heavy equipment wrecking yard on 212, just before you get to Boring.
[QUOTE="POTD was making a filler rod storage rack; still need to label them Steel, Stainless & Aluminum. The caps/rings next to the PVC tubes are for shorts of the same material. Pretty simple rack, schedule 40 PVC and sheet metal. Of course, after the fact I'm reconsidering the use of plastic around hot metal, but that's what the fire extinguisher is for!
Bruce
Bruce, I also use pvc for filler rod storage. One change I made after my first attempt was to leave a 2" gap between the bottom of the tube and bottom cap. That way when you drop a piece of filler rod into the holder that is shorter than the tube it is easy to get out (but is will still stay in the pipe). Never thought about fire, but I usually just burn my fingers with hot rod rather than other stuff.
Bruce
Thanks for the tip. That's why I put a cap and a coupling right next to each 20" length of PVC, keep the shorts there. My method was overkill, could have cut a notch or drill a big hole in the side about 6" up from the bottom and stick the shorts there or use your suggestion.
Bruce
