Got the thread cut eventually, took two afternoons. All cut by hand not power.
Received the new 80T gear wheel so I could cut the 39x4mm thread but half way through it slipped of the mounting shaft and I lost the thread registration. I remember when I last cut a 39x4 I used a bit of flat iron to hold it in place. Cant think why I didnt this time.
as you can see with number 1 because of the boss I cant fit the retaining clip, number 2 is the new plastic wheel.
Did a test fit to check the thread and it worked, but, when I removed the chuck and the shaft it wouldnt screw on all the way, there was a rough bit on the thread back at the bottom of the hole.
Back onto the lathe and re set up. What a job this was to try and get the thread registration back to continue cutting it.. Eventually did it and finished it.
A very nice fit.
That a lot of weight hanging out there.
Parted off the unwanted bit, not easily but not too bad. Thats a long bit of parting tool hanging out.
Quick face on the end and a skim from the outside
Now to bore and taper bore for the collets and thread the nose for the nut.
As a quick test I cant see any run out. Fingers crossed.
