- Dec 22, 2015
- 562
Go tired of looking for a wrench to loosen / tighten the QCTP hold down nut so I made a replacement that I would not have to look for. I can't take credit for the design or the idea ...... I got the idea from another post. All turned down and made shiny.
Here is the metric 14 x 1.5 thread all done.
Part mounted in my cheapo angle vise to get the drill angle perpendicular. Then drilled and tapped.
Mounted on the QCTP and ready to use. The handle is a piece of rebar that I turned down when I first got the lathe. I think I will add a ball to the end but will have to make a ball turner first.
Also mounted the hydraulic tilt cylinder from the Bobcat so I could bore the eye. It was way out of round. First time doing this sort of thing. Took a while to get it all set up straight and true but a great learning experience. Had an issue when I started boring. Seemed to start OK then things went sideways. There was a horrible banging sound and shudder. I shut the mill down and found that the boring bar had spun in the head. I was taking a pretty heavy cut because I read somewhere that the cut should not be intermittent and in order to get a light touch on the large dimension, I needed to take a heavy cut on the small one. Tried it again and the same thing. So I went to a light intermittent cut and then things went smoothly.
and the finished cut. A nice round hole that will get a new bushing made for it.
