I also wanted to share with folks who where curious how accurate those tachometers from eBay are. I verified the RPM's using a digital laser Tach. For those of you not familiar with this tool, they are used for many applications and are fairly inexpensive. My neighbor loaned me his. He uses it to set up commercial sliding gates and such in high security areas that specify open/close times.
A piece of reflective tape is used (cut small piece) on the surface your measuring and you point the laser dot holding steady and read the instrument once the number stabilizes.
I did two tests to verify RPM. A single piece of tape on the spider, then three pieces of tape dividing the larger number by three (more accurate reading).
Capturing the numbers on a digital read in a photo is tricky as not all numbers show up depending on angle of camera, but you'll get the picture.
The first test was done with one piece of tape reading 492 RPM on machine tach. The laser tach showed 491.9, so damn close.
Then three pieces of tape (evenly spaced) revealed a 2 PRM discrepancy, so yea, these tachometers are pretty darn close.
1459/3=486.333 RPM and the machine was reading 484 RPM (2 RPM difference).
Not sure why some photos are upside down, but you all get the picture. I think for $10, the tach is a good buy.
I hope this was helpful to someone.
