- Sep 28, 2013
- 4,395
Matt, How did you get the even angle on the boring bar cutter tip ?
I tried making my boring bar up for internal threading but by free hand with a small angle grinder and a template , annoyingly it always came out lob sided .
Hi David,
just trial and error and one of those fish tail gauges. I made a 1/2 thick tiltable rest for my bench grinder a while back which has been a boon grinding tools. I set the lead angle at 7deg or so and the reverse angle at 5deg, then just kept touching up until the sides were more or less equal and matched the gauge. Then some stoning and it was done. Same but opposite angles for the outside threading bit, but that one was 1/4in stellite which was a bear to grind - seriously hard stuff! HTH
