- Aug 12, 2014
- 269
What an attractive idea!, and what lateral thinking!.Today I needed a steel “washer” of about 4” OD and 2.03” ID. I used a 4 1/4” hole saw to cut a round slug from a sheet of 11 gauge (1/8” steel). Chucked it in the lathe and used a 2” hole saw to cut a slightly undersized ID. The 2” hole saw would have hit the flats of the external jaws, but I routinely cut from both sides when using hole saws, so as to get a cleaner result.
The problem then was how to bore the ID without running the tool into the jaws. What to use for spacers? AHA! I have a bunch of 8mm tall, 8mm diameter rare earth magnets. Stuck them on the jaw flats, then stuck the part on. The magnets even held the part in position while I tightened the jaws - without having to hold it in place by hand!
Just for fun, I miked a few of the magnets I have. They all seemed to fall within a .002” range in height. Not too bad.
HOWEVER ... these magnets absolutely LOVE swarf! And any crumbs that get on the magnet may cause the part to wobble. So be aware of this.
John.
