Been working on this off and on for 3 weeks and finished the labeling today. You can see my 4-80 TPI gauge, Die Handle, Allen Wrench, Screwdriver, Fishtail, Feeler gauge. This was an empty cigar box that I put to better use, body filled sanded and sprayed with some left over PPG Concept paint. The inside is a solid piece of Mahogany that I milled, the thumb nail for the dies was done by elevating the board in the mill vise and touching with a 3/4 end mill. The home made screwdriver slot is milled deeper on the handle end so you can push it down and the blade end will pop up. The Allen was drilled and driven into the wood to form a hex so it would not turn. The under side of the Mahogany has been hollowed out to store extra dies and left handed one that are rarely used any more and the entire piece can be lifted out, I then coated with a automotive clear coat to make it oil and cutting oil resistant. This layout was the 8th in a process of looking at it and then coming up with a better design until I settled on this final version. I put a small magnet under the fishtail to hold it in place.
View attachment 65547View attachment 65548
