4
4GSR
Forum Guest
Register Today
Brain,
Nice job on the repair you did!
That ought to last another four generations of use.
Here's what I've been working on this past month between the hours of 10:00pm and 6:00am.
I making a new cross slide and compound slide for my 13" Sheldon Sebastian lathe.
There's more to come. Will start a new post.
For my first reasonably complex shop project, I decided to make a handle for a Bison 2 piece milling vise I bought on eBay. It has a 17mm square drive and the only handles I could find with a matching socket are one piece and look like cast iron (though they may be forged steel). I wanted a Kurt-style swiveling handle. I started with a piece of 1.25 4140 and trued and faced it, then used freeCAD to model the handle based around the dimensions of my stock. I still need to round off the ears. I need to move my X axis DRO to accommodate my rotary table's handle and get some work holding gear figured out for it first.
Obviously the real goal with this one was to make a vise handle, not simply to have a vise handle
QUOTE]
Very nicely thought out and accomplished !!! Your handle has given me some ideas about a microscope stand that I am planning on machining.
Brian
Hello Goat Driver,
First of all , I need a real name.... like Bob or Ken to call you. )
Using the same boring bar that I had bored the gear with, I ground a 7 degree relief angle on a peice of HSS tool bit that had the same dimension as the key that I wanted to cut. In this case it was 1/4" . I simply ground a 7 degree end clearance angle, hand honed it with a small stone and oil, and mounted the tool bit in the boring bar holder with the square top edge facing the chuck and the 7 degree relief angle pointing back towards the tailstock. By eye, I rotated the boring bar until it looked like the tool bit was roughly horizontal.
This keying procedure is done without power to the lathe of any kind but muscle power. I engaged the back gears of the lathe to eliminate the spindle turning on me while keying. I also drove a wooden wedge between the cone pulley and the housing. Then I advanced the carriage towards the chuck until the tool bit was close to the bore opening and used the cross-slide to adjust until the tool bit was in close contact with the bore.
Whether the tool bit is exactly horizontal or vertical or anywhere in between is not important. What matters is that both edges of the tool bit are in contact with the bore at the same time. I rotated the boring bar and manipulated the cross- slide and carriage until both points of the flat were in contact. I then advanced the cross-slide .001" and used the carriage handwheel to push the cutter into the bore. I visually verified that it was cutting equally on both corners and made sure that the boring bar was snug and continued to feed 001" at a time and running the tool in and out.
You need to be patient and not be tempted to increase the cut to hurry it along. Just relax and get into a rhythm..... it took about 5 minutes to cut this keyway. I don't have keyway broaches as of yet and this was a method that was passed along to me that served the purpose and the end result was very good.
I hope that I haven't been too long in the tooth in my explanation and that I have answered your question. Don't hesitate to ask more questions of me. I am fairly new to machining and am here to learn...
Cheers...
Brian
