Milling without a milling machine
I bought an AXA quick change tool post and toolholder set from CDC tools. I am very pleased with the set - it looks and works nice.
Of course the T-nut was not machined as it fits many types and brands of lathes.
I decided to give a try to milling the T-nut on my South Bend.
First I had to narrow the entire "blank" which was to become the nut.
Yes, I did mount the cutter directly in the chuck, a no-no by many standards. Unfortunately the workshop is filling up with packed boxes for moving thus eliminating access to the left end of the lathe preventing me from using a collet.
I used one of the few milling tools I have - a fairly large keyway cutter to mill both sides off the blank. It worked well mounting the blank in the old toolpost. Note the toolpost setscrews on the right.
Next I milled the cutaway sections to create the T shape.
I used the same cutter to mill the cutaways. This time I mounted/bolted the blank directly to the cross slide using the old T-nut and a shim to get the depth of cut right.
The finished product ---
----- End View as finished
It fits very nicely, perhaps a little better than the original, slides smoothly, and works great in general.
My biggest learning experience was that climb milling can be tricky as the cutter may bite too hard, especially with some play in the feed mechanism (cross slide). It tends to pull the workpiece into the cutter. I had to get creative to allow non-climb milling with the crude setup as I was limited by cross slide travel.
Not bad I feel for an amateur with no mill !!!
