2013 POTD Thread Archive
Well, another project I started got put on hold because my internal groovers won't hold an insert for the size groove I want. Sooo, off came the chuck with piece intact, threw on a different chuck and started a different project. Here's a grinder hub for the B&S #2. It will have some special features that I'll show later. I decided to make it from two pieces of 1045. The collar and disk were deeply chamfered (almost 1/4") for solid TIG and weld-up. Oh man, I'm covered in 6's and blisters.
BTW: No, I didn't TIG weld it in the vise... It was 750 F when I was done welding it so, clamping in the vise makes it cool off faster. -And yes, I used ER80S because of the high carbon 1045.
Ray
All I did was set up and start cutting a ring gear for the speed reducer I am building.
After eating to much, I cleaned up my small shop after restoring my Lewis Horizontal Mill. Can't find anything until I return it to were it should be.
I worked on a glass cutting fixture for my sister to cut glass for picture frames, then I fixed my tap adapter to use on the fixture. Some general clean up and machine maintenance.
I took apart my half universal dividing head. The worm and gears run in an oil bath. When I sealed it last time I used too much sealant and the sealant got where it shouldn't go. I couldn't tilt it anymore. This evening I needed it for another project so I had to take it apart and fix it. Luckily I had used Loctite 573, which has low breaking power. Still it was quite a job and took most of the evening. That'll teach me to be more careful with sealant.
Well , it was actually yesterday , but I picked up my trailer full of machine tools , got them to their new home and got the lathe set up but not level yet . Got the base and column of my RF45 clone on it's base , head will be mounted and <hopefully> trammed in today . I was going to start construction on the foundry area to day , but it's raining here . I guess I'll finish up the electrical instead .
Snag
Snag...OT, but wanted to let you know I love the area you live in. Family and I regularly take a fall foliage pilgrimage up to that area. Stayed in your town many times.
I use the FLT if i remember the code right. they are the stand up style with only two cutting edges though. although they only have 2 edges i rarely have to toss one unless i crashed it into the end of a blind hole. the size i use for the 1/2" bars is not thread specific, have cut anywhere from 32 - 12 tpi with it so far and every thead has come out as intended. they are not the cheapest of an insert something like 10 bucks a peice but they do the job nicely especialy if you are threading with some speed on the spindle
Not much... Made that little mag-base holder for the cheapo HF swivel vise -which took all of 20-30 minutes. A piece of schedule 40 pipe welded to a scrap of plate. Then, I used it to hold that HHS bit and grind a perfect 60 degree threading tip.
Shop-related, I spent 2+ hours on CAD and another 2 hours searching the world over for some internal threading bars. And speaking of that, does anyone have thought/opinions on what insert style they like for internal threading? I was thinking about the IR-type (3 points) but noticed the inserts are thread-pitch specific. Are any of them thread-pitch agnostic?
Ray
Had a busy day with some paperwork issues but managed to turn-down the shaft part of the grinder hub. I designed the thing and wanted the shaft specs at 1.250 +0, -0.0005. Took three passes to get in the ballpark, took 15 thou off for the last pass plus a spring pass and the final dims came out 1.2499. Zero variance over the 1.875" length. -Really nice to have a lathe that does what you want it to (and knowing it can do it because it was aligned properly).
Well, this was actually 2 days ago.
Friend brought her bike to me to install a stereo. One of the brackets broke. The repair steps are pictured.
2013-03-29_13-22-27_934.jpg 2013-03-29_13-26-36_916.jpg 2013-03-29_13-51-27_425.jpg
2013-03-29_14-06-44_313.jpg 2013-03-29_14-25-59_175.jpg 2013-03-29_14-30-25_280.jpg
Was my first impromptu use of my micro mill, used the lathe (HF7X10) to make some spacers for another part of the install too!
A few months ago, this would have been a new part ordered and waiting for shipping. Was a big internal ego boost to look at it and
realise... Hey, I can fix that!
2013-03-29_13-22-27_934.jpg 2013-03-29_13-26-36_916.jpg 2013-03-29_13-51-27_425.jpg 2013-03-29_14-06-44_313.jpg 2013-03-29_14-25-59_175.jpg 2013-03-29_14-30-25_280.jpg 2013-03-29_11-39-21_415.jpg
