making the most of some spare evenings to get on with my various projects in the garage.
Then I used the bandsaw to cut a piece of alu plate to make a pill for an LED light conversion on my drill press
The pill is tapered to fit in the bottom of the old light housing. Now I need to drill and tap the screws to hold the pill in the light and the LED to the pill, then it's just a case of wiring in the LED and driver.
Hello MATTHEMUPPET
Thanks a mill for posting these pics.
U see what U may take for granted is really another opportunity for a Rookie to learn a lesson, especially Your method for making THE PILL.
What we really liked are Your detailed pics from start to finish, truly worth a thousand words, especially the second last pic which shows the COLLAR, WASHER and ALLEN HEAD BOLT to hold things together when U turned the PILL !!!
Had mentally grappled with turning discs etc., now U put the plan together !!!
Kudos to U, Sir.
May we say that THE PILL can, after this, now be grabbed in the chuck and both FACES skimmed/cleaned true ???
We will know for certain, and with confidence, what to do the next time around.
LORD BLESS
aRM
