- Apr 10, 2021
- 622
The spindle pulley should be larger than the motor pulley to gear 1700rpm down to 1200 ( example 4" motor to 6" spindle ). The motor pulley would have been swapped with the motor so is likely not original. You can go online and calculate the various mating diameters. Ebay is a great resource for NOS Browning, Martin, Matco, etc pulleys. The motor diameter will be easy to source, the spindle pulley might not be so if you can reuse that one and match the size, you will be golden. I'd not sweat getting a three belt one unless the price is good. BX belts ( or whatever the proper size is ) have better grip than old Vee belts did so two will be plenty for that machine. What is the spindle pulley diameter as that is probably original?
Dave
Dave
