Maybe this is a dumb question but here it is.
Using the BP over the weekend, had a 3/4 end mill, it had low power where I could have easily stopped the motor. Took light cuts and got the job done.
Should I be changing the belt ratio for more torque, slower speed vs. using the VFD in a case like this?
Thank you for your advice.
Hello Jim,
Since you didn't answer my question, I'll assume that you don't know. The motor can be wired in two configurations, star and delta. For best results with a VFD it needs to be wired in delta.
Hi Jim,
If you look on the side of the motor you should see a label indicating the two possible configurations of the motor. Now if you look inside the motor connecting box you should see jumpers on the terminals. Those jumpers correspond to the label. Please make sure that you remove the power to the motor before looking in the connecting box.
Somewhere I have a picture showing the label. I'll post it if I can lay my hands on it.
Hello Jim,
Thank you for the information.
I do apologize, I had no idea that the USA market had different motor configurations. I've only ever had experience with the dual voltage motors.
I posted that information based on experience with people that wired in a VFD without changing the motor to delta and suffered loss of power.
To Janderso, I'm sorry if I mislead you ! I was unaware of a single voltage Bridgeport motor.
