- Jul 14, 2017
- 2,463
Today with less than an hour to spare, i quickly put the engine on a stand, made a mess and found a mess. With the engine block upside down i heard couple of chunks fall out and found couple of pieces of steel. Remove the bolts from the oil pan and took it off, this is the first time it's being taken off and the rubber gasket is still in great shape. That revealed the big problem i suspected this engine having. The oil pan was full of garbage, pieces of steel, rubber and babert material. The big pieces of steel are from the timing chain guides that has disintegrated and someone install new one and left them floating. Took off the pistons and the bearing has chunk missing, it never spun a bearing but from setting the oil has eaten the bearing material, i'll take some better pictures later, the main bearing worn even worse and the crank and lots of lines in the journals, i'll be using the crank from the other engine or i'll have this one regrind. The engine block is in good shape, the cylinders have a ridge at the top but no other defects. Because of my time restraints i had to stop, but i'll get my micrometers and measure everything out to know do i need to have the cylinders bored or just have the block and head resurfaced. I hope you like seeing staff like this, it as bad as i expected, i'm surprised i've not found and wrench or screwdriver in the oil pan.
