- Jan 15, 2016
- 87
Last year I made the newbie mistake of buying a lathe with a worn out bed. Live and learn,,,lol. I made the mistake of buying a new chuck, qctp, and some other parts before I realized the bed was junk. The lathe has now just been sitting,
I have now stumbled across a possible replacement bed. I was at a guys place last night for something unrelated. I seen he had a lathe bed sitting there. I could not remember my way measurements at the time. His bed does have 3/8'' ways and 2-3/4'' in between the ways, and now I know so does my bed. My bed is 36''. His is 42''. That will be a welcome upgrade. I don't know yet if he has a lead screw and what size it is if he does. I need to go back and clean it up and get some good measurements for wear. But from what I seen it looked good.
I have read where Robert says there are 4 (I think) beds in the earlier years. And I think they will mostly interchange?
Info on my lathe that may or may not matter:
Thinner change gears than later models, no qcgb.
No power cross feed.
Babbit bearing headstock.
5/8'' lead screw.
Just some random questions.
1. If his bed is newer with the other type bearings will my headstock still bolt up?
2. Does it matter if his had a qcgb? I'll just have extra holes. I don't know if his had it or not. I don't know where the qcgb mounts,,,lol.
3. If he has a 3/4'' lead screw can I convert my carriage half nut and make it work? Or is there a work around?
4. If I have to buy a lead screw is it still worth getting this bed?
5. Can you shorten a longer lead screw?
6. It looked like the last bolt hole on the rack, on the tail stock , end MIGHT have been broke, maybe. Could that be repaired or would it need replaced adding to the cost.?
Well that's all I can think of for now. Thanks for any info.
My 1936 10D when I first got it.
5/8'' lead screw.
