This is the process that I plan to use to scrape the bed:
1. Since the uprights are off the machine, and I intend to leave them off until I have concluded the scraping of the bed ways, I need to compensate for their weight. I will measure the components, model them in Fusion 360 and derive a weight from the model. This means is preferable, as I will need a model to design the drive, and besides, I don't have a set of scales capable of weighing the parts.
2. Determine the location and amount of weight to hang under the machine bed to simulate the weight of the rest of the machine, which won't be there. I believe this will be necessary for this machine, as the bed is pretty spindly and there is likely to be significant (in the neighborhood of a few thousandths of an inch) sag just due to weight that I want to ensure is incorporated in the scraping.
3. Cut the center groove deeper. I plan to do this with an angle grinder and jig. It doesn't have to be accurate, it just provides clearance, and the wear is so bad it will need to be deepened.
4. Do a preliminary scraping on the ways. This will just be to smooth them out a bit, I don't plan to use a straight edge for this. The angle grinder and a jig may be something to think about for this step, as well.
5. Level the machine from the reference flats where the uprights were bolted on.
6. Fabricate a V block to go in the ways for the level to sit on.
7. Map the ways using a master precision level.
8. Come up with a scraping strategy based on the way map.
9. Fabricate a measuring jig to ensure that the ways remain parallel and in the same plane during the scraping process. This will also act as the reference surface for the scraping.
10. Scrape the ways using the jig and master precision level to get them correct. I am shooting for .0003/foot. We'll see how that goes.
11. Scrape the platen ways for smoothness. They don't need to be too smooth, since I'm using Rulon on them and a rough surface will help with the bond.
12. Epoxy the Rulon to the ways.
13. Reassemble the planer.
14. Use the bed ways as the reference surface to scrape the platen.
15. Scrape the platen, checking the level of the top using a DTI on the crosshead. This doesn't need to be perfect, but I would like to get it within a few thousandths. It will be planned flat once everything else is completed.
16. Fabricate a motor drive.
17. Cut metal.
Have I missed anything? I have a car rotisserie that may be useful for scraping the platen, I would need to fabricate some mounts for it as well.
