I didn't buy oil from PM, so can't answer your question specifically. The manual specifies Mobil DTE Heavy/Medium or equivalent for the headstock, carriage feed gearbox (Norton) and the apron.
This is the oil I use in the headstock and apron, and I use the Mobil Vacouline 1409 for the ways, Norton gearbox, and oiler points on the carriage and the feed/threading shaft ends. The Vacouline 1409 is the same as
Mobil Vactra No. 2 with tackifiers added so that it stays put and doesn't run off nearly as quickly. For the change gears, I use a spray-on lube that doesn't fling off and coat the inside of the belt/gear cover - it has a wax-like consistency and brings down the noise level of the gears considerably.
This is the stuff:
