Don't know on your particular model, but Craftsman used that motor on a lot of the power tools they made, everything from drill presses to band saws. That is one of the best motors they ever used and the HP ratings on motors back then were more conservative than now. The only downside is they use a flat capacitor in the base that is no longer available. When they go bad you have to do some adapting to replace it with a modern round or oval one. At some point they changed to 5/8" shaft motors and for a lot of their tools afterwards if you bought a replacement motor pulley it would be a 5/8" bore and come with a 1/2" sleeve so you could use it for either shaft size. The quirky thing about them was the power switch, when used on a drill press, up was "on" and down was "off".
