10F with TH54 bed....getting it running again. Need stuff..where and what?
Hi guys, I finally put my old Atlas lathe back together and actuall made the first chips in almost a decade with it. I need to go get some tooling for it, and right now my project is bead roller dies. About 3 inches in diameter, with varying profiles from a square groove to a rounded protrusion, and a inside stepped bore.
Is there any advantage to any particular tooling setup? Is there a hot deal out there on a QC toolpost with carbide insert cutter bits?(I think that is the best way to get a rigid toolpost that won't move around like the lantern one seems to want to do) Do I need a set of boring bars or?? to make the step bore inside my die? (3/4 and one inch bores with a square shoulder between the two.The part is about two inches long)
With the lathe I got two steady rests but each is a different style and missing the bed holddown part, and each one is missing one of the follower inserts. I also have a couple of centers, the one that spins has play in it.....and a lathe dog, and a tailstock drill chuck. It was equipped with the lantern style tool post and I have a few regular steel cutting bits with holders but they don't stay sharp very long at all. I have the lathe going as slow as it will without using the backgear, maybe i need to use it and slow down more..
I'll need help figuring how to make a radius externally on a beading die. I guess I could run the x and y directions with the crossfeed and compound dials but how to make it a smooth curve unless I use a file to shape it, I dunno. Any ideas??
$$$ is tight right now, work is really slow, but I need to get cracking on these parts while I have time.
I have a bunch of pictures on my photobucket albums, don't know if you guys allow image links or not but my user name over there is fbillsjeeps. I'd be glad to post some pics but don't want to step on any toes. Can I post an IMG code link? Or is it a must to download to this site?
