Rabler said:
I'd be interested in a little more description of the closed loop encoder used with the drive. I understand the concept, would like to hear more about what your process was for coming to this particular design. I have a DC motor that I could try to resurrect using some form of modern controller, but a VFD approach has merit. I would be inclined to retain the back/reduction gear but would need to cut a few gears to replace worn out ones in my current reduction gearbox.
To understand my choices in drives it helps to remember that my original goal was to get to the performance of the original DC drives. One of the things that people really like about the DC drives is their abundance of torque even at low rpm’s. Closed loop systems do supply a high degree of control over speed and position. This coupled with the braking does amazing things for the ESLR. But these are not the only advantages.
Closed loop systems such as mine have the ability to supply a 200% boost in torque throughout the range including all the way down to 0 rpm or stall. The reason they can do this is the encoder takes information from the motor in real time and relays it to the drive. This information is supplied regardless of speed.
Sensorless vector drives can boost torque up to 100% and down in rpm to about 10% of the motor’s rated speed which in the case of these four-pole motors would be around 170 to 180 rpm. The reason torque falls off so much as the rpm’s go down is because with a reduction in motor speed there is less feedback for the drive to interpret and make adjustments.
An example of this I believe can be found in a test that the late Harry Bloom performed with his 5 hp sensorless vector drive and published on PM. His machine was a 4,000 rpm machine. The following test was performed in direct drive. For the test he used a 1 ¼” piece of 1018 steel. His spindle speed was between 150 and 200 rpm. Depth of cut was .180. The feed was around .015. Harry said that upon attempting this cut it stalled the drive. He also said that he would not repeat this test as he believed it was close to the maximum ability of the machine.
I however did repeat this same test with the mg machine which is an 4,000 rpm machine that was reduced to 3,000 by an increase of the top pulley size. The result was a slowdown approaching a stall, but torque was quickly applied and then continued to advance the cut. The result from the close loop VFD machine (which was a 4,000 rpm machine with 1:1 open belt drive pulleys) was a much smaller initial slowdown and a much quicker response back to the original rpm’s. Another example where something like this might be encountered might be the engagement of a large drill bit where the need for torque rises quickly and speed drops.
I believe the close loop machine more closely imitates the performance of the original and perhaps even an improvement in terms of a more seamless transfer of power from an unloaded condition to a heavily loaded condition. One area I believe the DC motors are superior is if the DC motor and the VFD close loop motor were coupled together, I have no doubt that DC motor would win this tug-of-war. But at this level of power, the 10EE would lose. There would be more power than needed.
The cost of the drive, interface module, encoder, and cable along with the Black Max 7.5 hp motor and brake was $4,000 in late 2019. There is more need for additional tuning beyond the initial run in and set up of parameters. This drive was hooked up to an oscilloscope twice – once for set up and once for some changes I wanted. DP Brown supplied all the consultation and technical support including tuning for no increase to the initial costs. One side note, this same system with 5 hp would have been $3,500. For the extra $500 I decided to go with the 7.5 but this also comes with a little more complication with the back gear box.
My reason for this post was not to promote this drive or even suggest it is the best method as there are other methods such as larger motors without back gear and even servo drives. But I cannot comment on them as I have no firsthand experience with these in conjunction with a 10EE. In the final analysis I believe I accomplished my goal and am pleased with the results.
