10EE Restoration and VFD Closed Loop Conversion
tailstock4
H-M Supporter - Gold Member
Sep 28, 2022
177
I posted a reply in another thread and decided in order to reply more fully that I would start a new thread.
In the earlier thread I shared some pictures of my Monarch 10EE VFD conversion. It’s a 1968 modular machine with a maximum speed of 4,000 rpm. My conversion retained all of the original controls including the ELSR, and I also retained the original back gear. I chose to use a Black Max 7.5 hp with encoder in a closed loop system. The drive I used was a Nidec M701 with an interface module. And it also has a 20-ohm 1,500 watt brake.
I decided to retain the 4,000 rpm and to change pulleys to 1:1. This increase in drive rpm not only had ramifications for motor rpm and hertz but there were also some mechanical drive considerations that have to be addressed and even modified.
I had a chance to compare the performance side-by-side with a 1952 10EE motor generator that I also did some restoration on. The drive in it was in excellent shape and original. I could also talk about this if there is interest.
The mechanical condition of this machine was really good. It was a one owner machine out of a lab and the ways were in really good condition. There was about .0145 clearance between the flat tailstock way and the underside of the saddle. It did need spindle bearings because the front flange bearing had an issue on one point on the outer race.
I did dismantle the entire machine, replaced quite a few bearings overall, cleaned and painted the machine, and of course went through the oil system.
As far as the accuracy of the machine, I’ve include a picture of a test bar it cut after new spindle bearings. The picture also includes a 1020s Rivett test bar beside the Monarch’s because I replaced spindle bearings and restored that machine also.
Regarding the drive conversion, it is probably helpful to state that my goal was to achieve a performance equal to the original drive. So I chose to keep the back gear and go with a closed loop tenv motor. I know that many believe that a sensorless vector drive is adequate for this application. And I believe in theory that is correct. But after talking with some techs and engineers, I came to the conclusion that application is sometimes different than theory.
I have four other VFD drives in the shop (Hitachi, Lenze and Baldor) which are sensorless vector. The difference is smoothness, quietness, and responsiveness of the drive especially at low RPMs down to zero. In fact, at zero I can grab a 6” chuck, start to turn it, the drive will grab it back from me, return it to its position, and I am unable to hold it. The drive reacts quicker to changing torque requirements than do the sensorless vectors I have. Also, the drive and motor combination seem to produce little to no heat regardless of rpm or ambient conditions.
One other performance advantage was the installation an interface module which allowed a tech a DP Brown, the supplier and consultant on this drive system, to connect directly with the drive to tune parameters and view the results via an oscilloscope in real time. I was able to watch this via a connected laptop. Performance was enhanced from this step.
A test I did that probably everyone could relate to was to chuck up a piece of 1018 cold roll steel, drill a small pilot hole and drill the 1” hole at around 130 rpm in direct drive and it had no problem with this. When using a 6" steel set-true chuck, performance when acceleration and deceleration are turned up are approximately 0 to 4,000 rpm back to 0 in approximately three seconds. And it will do this time after time.
I discovered that when setting up deceleration rates all I really needed when using the ELSR for threading at about 400 or 500 rpm was for the carriage to stop almost instantly. In other words – no coasting. This gives you a very repeatable result with little need for much of a relief cut. Acceleration rates I adjusted to a more comfortable rate.
In the next post I can talk a little more about the actual gear box modifications and materials used in the electrical conversions plus the reasons for my choices.
Below are the pictures of the restored machine and of the completed drive conversion.
IMG_0346.jpg IMG_0347.jpg IMG_0348.jpg IMG_0349.jpg IMG_0354.JPG IMG_0336.jpg IMG_0330.JPG
Impeccable build job, probably the best I have seen on a 10EE. A beautiful build and really well thought out.
I had looked into encoder feedback on a previous lathe builds but the cost benefit was not there, and when you factor in that with a multiple speed gearbox one does not need to run the motor to very low speeds/Hz. Sensorless vector is an approximation and the algorithms used can make a significant difference between VFD's, but an encoder gives one several orders higher tighter speed control. I also feel that your ELSR probably performs better in your build than the original DC drive given the encoder/electronic braking. I use an electronic sensing stop system for in some VFD systems I build, the repeatability of the stop is less than 0.001" threading at 500-600 RPM at a 8-10 TPI. The main limitations being more the refresh rate of the sensor and the play in the drive system, as opposed to the VFD. The parameter programing is also a factor, and this is where the encoder can give very precise stopping and repeatability.
Impressive job! Inspiration for getting my 10EE rebuilt.
I'm interested in the drive mods and comparison with the original dc lathe as well.
What range to you use in open gear before dropping into back gear ? Dave
Thanks, mksj and rabler.
mksj: I’ve long admired your advice and your willingness to share it. I know it has benefited me.
I chose to retain the back gear in part because I had the ability and the machinery available to do so easily. I don’t use back gear so much for power, but more for large diameters in difficult material that I want to maintain a reasonable metal removal rate and be less taxing for the machine. My range of rpm is 0 to 800 in back gear. The reality is I almost never use the back gear. In my shop there are larger machines for this work. But it is nice to know it’s there if I needed it.
As many may know machine tools are all about having the right amount of excess.
I will get to the drive mods and the comparison in a later post.
I'd be interested in a little more description of the closed loop encoder used with the drive. I understand the concept, would like to hear more about what your process was for coming to this particular design. I have a DC motor that I could try to resurrect using some form of modern controller, but a VFD approach has merit. I would be inclined to retain the back/reduction gear but would need to cut a few gears to replace worn out ones in my current reduction gearbox.
How does the encoder wire into the VFD? I’m very fuzzy on what the encoder actually does within this sort of set up/use.
Will
I believe based on my research at the time that I could maximize the drive’s performance a little more with an encoder not only in positional accuracy in relation to the ESLR but also in some torque enhancement and better reaction to changing load requirements. I saw in another forum that this setup may be close to the same one that Monarch currently uses in their 10EE remanufacture process.
I am not a VFD expert. Whether this modification is worth it or not is a judgment call – much like retaining the back gear or deciding what horsepower to use. I’m pleased with how it turned out for me.
As for the exact encoder I used, I don’t remember off the top of my head, but I could get it for you if you want it. I can also tell you that with the back gear, 7.5 hp Black Max and encoder, it takes every bit of room in terms of length that is available in my 1968 modular machine.
