- Dec 18, 2016
- 18
Recently obtained an early Atlas 10 D, babbit bearings, removable bearing caps, 5/8 lead screw. Lathe had grease fittings rather than oilers which I.m told is a severe no-no. Finally had time to look Removed bearing caps, Left had lube & bras shim, right dry, no shim, spindle somewhat ugly and the bearing had a small hole in the center. Assuming the bearings can't be replaced like shell bearings Any help would be greatly appreciated as I am new at this
