- Jul 2, 2014
- 7,571
Jeff, first fit the plate to the chuck so it is located rigidly. Tight fitting round (or square or whatever) steel pins to fit the narrow portions of the t-slots below the plate along with the centering pin you made will effectively make the tooling plate an integral part of the RT. Do that first. Try to have the plate fitting on the center pin tighter than the .001-.002" clearance you mentioned. Not only will it be less accurate if it has play, it will also be less rigid, which can cause chatter when using it. Make everything fit tight and snug.
