- Feb 7, 2013
- 792
I'm kind of in the middle of doing something very similar. Used a 5" long chrome moly tube that I JB-Welded onto the nut. Turned down a couple steps on the dial mount end on the inside to house an acetal bearing for radial load, and like you, have needle bearings for axial load. Just need to make a fitting on the end for the outer needle bearings, then a hub for the dial/reader line.
Just got off of ebay looking for a larger dial and stumbled across a bridgeport dial:
Milling Machine Part- Dial w/200 Graduation Table/Cross - $36 shipping included
http://www.ebay.com/itm/Milling-Machine-Part-Dial-w-200-Graduation-Table-Cross-/171021870749
200 divisions, but from the specs on that page... ~3.25 diameter. Ought to be here within a week... and should be just a tad easier to read...
On mine the ball bearings are handling the thrust the needle bearing was an after thought for the dial to spin against. The bridgeport dial should be easy to read but if once you get it you do not like the size all is not lost I have seen many setups made with a bridgeport dial. Most machine it so it fasten's on the back of the spindle and then use a pointer to identify each line then they scribe each graduation on a smaller dial.. Ray
