- Feb 15, 2021
- 11
Just acquired an old Light Machines mill. Can't get the z axis (vertical) to operate smoothly and consistently. Have cleaned and lubed the ways, adjusted the so-called "gib key" and carrier nut. But it still stops intermittently and groans. Can't trust it to run a program. Anyone have advice on this dinosaur? Is it a motor problem or the shaft connections? Expensive boat anchor if I can't get something figured out.
Thanks!
Thanks!
