- Jun 15, 2017
- 525
I welded up a project that turned a Harbor Freight 26" tool chest into a welding cart. It went so well, I'm thinking of putting my belt grinders on a rolling chest.
I have a 3HP 2x72 grinder with an Origin Blade Maker frame. I also have a 1x42 Rockwell grinder with a treadmill motor. They're both sitting on a plastic Northern Tool cart 40" long. They're not attached to it. I mounted them on heavy plywood.
It works, but it's not great. The cart supposedly holds 500+ pounds, but the top shelf is sagging. Also, the bottom shelf is not useful. I can put a few things in there, but they get covered with grinding debris.
I'm thinking maybe I should get a Harbor Freight Yukon 46" chest. These things are supposedly the best deal in the price range. They come with heavy wooden tops and 9 ball-bearing drawers. I could put the grinders on top, screw the VFD box for the big grinder to the side of the box, and put my belts and other junk in the drawers. I don't know if a tool arm will fit. I have to measure.
I figured the drawers will keep debris off the accessories. On the other hand, the chest is 6" longer than the plastic cart, and it takes up more room.
What are other people doing with belt grinders? I could weld up a mobile stand for each grinder, but that wouldn't help me with storage or keeping accessories clean.
