- Apr 22, 2016
- 965
As I said back in December
So back to the grinder again. Today and yesterday I mounted the feed screw and 1/2 nuts. Now to figure out a way to open and close them.
The feed screw will be driven with a wheel chair motor w/ speed control from the right side. There is a nut and washer on each end of the rod for end play adjustment. The nuts have a locking set screw pushing on a lead pellet to protect the rod. All the mounting hardware has oversize holes to allow for line up of the parts.
This was supposed to be a winter project but I'm now changing the timeframe to 2021. But that may not come about either.
Thanks for looking.
Aaron
Now in the last month with warm weather again that wood is almost all cut up and split.Well, finally getting back to this project
My brother and I pulled a lot of firewood out of our swamp to where it can be cut up and split next spring.
Thanks for looking.
Aaron
