- Oct 3, 2015
- 983
You only have to drill 1 hole. The un-tapped hole in front of the trigger is in the correct place, it just needs tapped. The middle hole is in the same place for both bolt spacing's, so you only need to drill and tap the front hole. Depending on what stock you are going to use, you will have to have the correct trigger guard.
I re-drilled many of these because of the confusion of action screw spacings that Savage uses on the target actions. I have built hundreds of stocks, and inevitably someone gets the wrong spacing because Savage made a run of target actions using the wrong macro for the drill cycle. It's a lot easier to re-drill the receiver than to move a pillar. I have found that the longer screw spacing is more accurate than the short one, as the short one is very bedding sensitive.
The way it looks, you are only about an hour and a half away from me.....if you showed up with some donuts, we could poke a hole in it and compare scars!
