Working on the sg today and the column only moves back and forth 3 inches and it should move 6!
Braeden P Registered Registered Joined Sep 1, 2020 Messages 1,593 Jun 7, 2021 #1 Working on the sg today and the column only moves back and forth 3 inches and it should move 6! Attachments 64479985997__12304CFD-B6A1-49D6-9CAF-8301C56AF067.MOV 4 MB
Shootymacshootface I make little metal out of big metal. Registered Joined Mar 17, 2018 Messages 1,400 Jun 7, 2021 #2 Sometimes, that's how it goes.
B benmychree John York H-M Supporter Gold Member Joined Jun 7, 2013 Messages 10,093 Jun 7, 2021 #3 I'm thinking it needs some fixing ---
brino Confirmed Tool User H-M Lifetime Diamond Member Joined Jan 2, 2014 Messages 8,852 Jun 7, 2021 #4 Braeden, I feel your pain, but unfortunately have no advice. I am glad the project is in your hands, it is worth saving and you have the smarts and tenacity to figure it out! -brino
vincent52100 Registered Registered Joined Mar 26, 2014 Messages 211 Jun 7, 2021 #5 God knows I’m ignorant to the 4th decimal point but could the problem be something under the table locking the screw. WAG on my part.
FOMOGO Active User H-M Lifetime Diamond Member Joined Sep 2, 2013 Messages 5,100 Jun 8, 2021 #6 Sounds like something is HALF a**ed there. Time to pull the table, and take a look see. Bent screw maybe. Mike
Braeden P Registered Registered Joined Sep 1, 2020 Messages 1,593 Jun 8, 2021 #7 I think the screw is to short so I will have to pull the table and loosen some bolts that are rusted and covered in paint!
R rjs44032 Registered Registered Joined Sep 20, 2019 Messages 81 Jun 8, 2021 #8 Many SGs have stops on both the X axis and Y axis. Check for these before tearing it down. Hope this helps. Best Regards, Bob
Mitch Alsup Registered Registered Joined Nov 17, 2017 Messages 1,525 Jun 8, 2021 #9 I would guess you have not found the stop that is stopping the movement.
Braeden P Registered Registered Joined Sep 1, 2020 Messages 1,593 Jun 8, 2021 #10 now when I get home time to get covered in grease and goo that covers that machine! and that stuff stinks!
