WTB: Domed Handle
Rick_B
H-M Platinum Supporter
Dec 10, 2011
448
Looking for what I call a domed handle
The overall length is 2-1/2", the threaded stud is 1/4-20 and about 1/4" of threaded length. The fat part of the handle is 3/4". Nothing magic about the dimensions except the thread size.
Thanks
Rick
McMaster Carr
Got something you could use in the garage if it would work .
Not sure , but found these yesterday in one of the Vidmars while cleaning out . I made these years ago on the cnc lathe . They are made to run a SHCS thru to mount .
Kipp catalog item. Zoro or Grainger carries them.
They might work but I need them to tighten by turning the handle. I could epoxy the through bolt I suppose. What size through bolt are they made for? Are they roughly the size noted above - 2 to 3 inches long and about 3/4 dia at the fat section?
Rick
These are a bit shorter for the smaller lathes I fixed up . I put them back in the box but they are made for 5/16 bolts . I modified many to work in the past , but maybe too short for what you need . Next time out I'll get an OAL .
OK - I would need to modify them or the bolt - I need a 1/4-20 stud. Thanks anyway
Rick
