- Apr 29, 2019
- 2,061
consider this point naysayers....
almost every naval vessel over 100 feet in length, will undoubtedly have a fully functional machine shop on board.
the machines are never level when underway.
can anyone tell me how the navy machinists can make just as accurate part when underway, as you can on your perfectly leveled lathe or mill to .0005"????
the naval machining must be magic, or, possibly too much emphasis is put onto esoteric gymnastics.
the latter appears true, in my pee brain
It is not the "level" of the machine that matters. The machine being "level" just makes certain setups easier. What IS important is the machine be solid and square. The machines in the shop on a navel vessel are mounted very solidly to the floor so that they have no twist or flex happening. This also keeps them from flying around in heavy seas. That is what is ultimately important. It is just easier to get it right at level than by other means. This just means that those sailors have to work a bit harder to get the machine initially set up, and may also have to work a bit harder to do setups for individual parts.
Erik, this will also apply to you. As long as your base is solid enough to not allow flexing you will have no problem with mobile machines. You will just have to work a bit harder to square up a part while doing a setup since using a level will not be an option. Yes it can be done. But mobile just means that it will not be level (because garage floors are never level) which does not really matter to the function of the machine.
