- Aug 22, 2012
- 4,121
Would this motor be strong enough to power my 9x20 lathe?
36VDC, 500W, 18.3A, 2500 rpm
The spindle is only around 9/16” dia so not very beefy and I would have to make a decent pulley but at that speed it would have to be very small to get a reasonable reduction which would also mean a greater chance of belt slippage.
If I use the original speed controller from an E-bike would the low speed still have sufficient torque for the lathe.
I would also need to add a cooling fan.
Why do I want to use it?
Because its been sitting on the shelf brand new for 6 years when I was going to use it for an E-bike.
I have been considering getting a 1hp 3 phase motor and vfd but this would be a far cheaper method if its strong enough and can run long enough without overheating.
Thoughts? Ideas? Anyone.
