- Dec 18, 2019
- 6,464
I know about the mess, and covering things up. Have seen the pictures of the paintbrush trick. I've never machined it so I don't know if somethings are bad to do.
Are there any major gotchas? Heard about hard spots.
I made a design that has 1/4-40 threads tapped in cast iron. Is this a bad idea? I've tapped an M5 hole in cast iron and it was ok.
Actually have two different projects, a diamond dresser for my carbide grinder, and a back plate for my lathe.
First one to tackle will be the diamond dresser. That's a milling project. Due to the possibility of hard spots, should I go with carbide end mills? Can I use a carbide fly cutter on cast iron? What about drilling? HSS ok?
Grateful for any tips.
