- Aug 22, 2012
- 4,121
On my 9x20 asian lathe the cross slide divisions are 0.025mm per division.
So, if I have a 12mm dia rod in the chuck and wish to turn it down to 8mm I nudge the tool tip to the rod and zero the cross slide dial.
I need to remove 4mm of material, so, as the cross slide feed removes twice the amount of material that the feed states I divided 2mm by 0.025 to get 80 divisions of feed.
I then start turning using the fine auto feed advancing the cross slide 0.5mm at a time (I'm not comfy with heavy cuts yet) until I reach 80 divisions.
When I measure the new dia its never 8mm its usually something like 8.2 to 8.78.
I know its not a huge amount and I can cut a tad more to get to size but I'm wondering why it doesnt add up.
What am I doing wrong?
I use digital calipers to measure the dia.
Thanks
Thanks
