What is the best or easiest way (not always the same thing) to mount a a pair of 3 groove step pulleys to the lathe so I can true it up. I want to keep it concentric to the center bore as much as possible.
I have only been using a lathe for a few days time, so I might be missing something simple. I am trying to true up the pulleys on my 4x6 HF band saw. I thought it would be an easy learning project, but I'm unsure how to mount the work.
Each pulley is visibly out of round. It's chewing up the belt & it is a source of vibration, that I'm trying to minimize. The center bore is a good fit on the shaft with no wobble. The motor shaft has almost no run out, but the pulley outside, grooves, & front/back looks to be off quite a bit as it spins.
I have a 3 jaw & 4 jaw chuck, live & dead centers, a faceplate, but no lathe dogs yet. The lathe is a grizzly G0516 w/milling attachment, so it's big enough to do the job. I don't think I'll butcher the part unless it comes loose when turning.
I've tried to put it in the 4 jaw chuck first, but I haven't got the hang of centering it yet, & I get way to much run out measuring from the center bore. The pulley was cast so I can't be sure that it was drilled perpendicular to the pulley groves or the faces of the pulley, so that's probably half my problem. I not only have problems centering the workpiece in the chuck, but I have problems getting the center bore parallel to the center axis of the lathe.
The 3 jaw chuck is worse than the 4 jaw chuck in regards to runout, so that's out.
I thought about turning it between centers, but I'd have no way to turn it without lathe dogs.
My other thought was to turn a hunk of scrap aluminum (I don't have any steel that size yet) down to the size of the bore & with out removing it from the chuck put the pulley on it & tighten the set screw, but I'm not sure that will work, even with a flat for the set screw to sit on. The other pulley I want to do this to has a different diameter bore. So I'd have to machine 2 pieces to a specific diameter, but not able to do that every time, yet. Like I said I'm new to using lathes.
Is there a way to do this that I'm not seeing? Or will one of the methods I thought of work? Thanks for any help. I did search but I always see people making new pulley's from scratch & I don't have any material to do that today.
