Work holding and tool choice for beveling angle steel on mill
tominboise
I am working on tooling for a home shop finger brake. I need to bevel one leg of a 3x3X1/4" A36 angle, 45deg, to create a tool with a small bend radius. I am using a PM728VT bench mill and am wondering how to hold the angle and what tool bit would be best. I have a 1" carbide face mill and various HSS end mills. If I had a Vee block, I would guess that I could use that to hold the work at 45deg and then the face mill to cut the bevel. But I do not own a vee block at this point in time. I have various fingers to bevel ranging from 2" to 9" in length.
How exactly 45 degrees does it need to be? Would ~43-47 degrees do? If you don't need an exact 45 angle a little creative work holding should be able to get you quite close.
It does not need to be exact, just consistent down the length of the tool. I have a 4" vise. Not sure how much I can hang out each end and not get a bad vibration.
Maybe put the apex of the angle iron into one of the slots on your mill table and clamp it to the table? Maybe a round rod inside the angle iron for extra clamping force in the center? ... am not trying to offer a perfect solution, just some ideas to spur some thought. \o/
Or Cut off some spare pieces of the angle iron and tack weld them to the ends of the angle iron for support? --> /\\/ or even /\\//\ and clamp straight down to the mill table?
90 deg countersink endmill
Another vote for the 90° cutter, which will be useful on other projects and it's not expensive.
Bolt the angle right to the table (no vise), with a piece of aluminum (or whatever) under it, spacing it up just enough that the cutter can't touch the mill table.
Me, I'd use a 45° wheel cutter like this. Typically intended for horizontal mills, but you can get an R8 arbor that fits them.
The main advantage is fast metal removal. If you have a long cut to make, this will take much less time than a typical little 1/2" shank chamfer cutter. The big cutter will stay cooler and last longer, and the fat arbor is way more rigid.
The cutter I linked to is under $30 incl. shipping, but the arbor will be expensive if you don't have one, and/or don't have another use for one.
I have two arbors for cutters like that:
The one in the forground is common, generic, not too spendy. I shortened mine to be able to bring it closer to the table but as you can see the cutter needs a spacer below it and that big nut. The one in the back is a Petersen Flush arbor, super cool but spendy. I lucked into mine used, so maybe start searching for one. This one can cut dovetails.
The cutter I linked to is for dovetails I think, so in order to cut the bevel you want, you'd flip it over, and run the mill in Reverse.
